ERROR
When using the sde.version_user_ddl.edit_version procedure in Oracle, the following error message displays when attempting to stop the edit operation:
"SQL> exec sde.version_user_ddl.edit_version('DEFAULT',2);
BEGIN version_user_ddl.edit_version('DEFAULT',2); END;
ERROR at line 1:
ORA-20048: Lock <893,1528,Y> not found, not deleted.
ORA-06512: at "SDE.VERSION_USER_DDL", line 765
ORA-06512: at line 1"
If the session has previously encountered the following error when calling sde.version_user_ddl.edit_version('DEFAULT',1) multiple times, the above error message displays when stopping an edit operation:
SQL> exec version_user_ddl.edit_version('DEFAULT',1);
BEGIN version_user_ddl.edit_version('DEFAULT',1); END;
ERROR at line 1:
ORA-20176: State 1528 from version DEFAULT is not closed.
This error is expected, because the state is already open. Applications should not attempt to start multiple edit operations on the version prior to stopping the edit operation.
Article ID:000009431
Get help from ArcGIS experts
Download the Esri Support App
