HOW TO
Lock a Python script so it cannot be edited
First Published: May 5, 2016
Summary
Instructions provided describe how to lock a Python script so it cannot be edited. When scripts are going to be shared but the code needs to remain unchanged, compile the PY file into a PYC file. This ensures that the users are unable to make any changes to the existing code within the scripts. A PYC file is binary in nature and cannot be read directly.
Procedure
Below is code that compiles a PY file into a PYC file.
PYC files run even if the PY files are not present.
Code:
import py_compile
script = "C:\\temp\\myscript.py"
py_compile.compile(script)
This code can be entered as its own PY file or can be entered into the Immediate Window of PythonWin.
The PYC file is created in the same directory as the PY file.
Article ID: 000010321
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
