PROBLEM
Loading large files in IMemoryBlobStream causes out of memory error
When loading large files (over 100MB) using IMemoryBlobStream.LoadFromFile an "out of memory" error may be returned.
Cause
The interface is not allocating memory correctly.
Solution or Workaround
The file is being loaded into memory and the available resources need to be allocated better.
  • Try to limit the size of the input data as much as possible by compacting personal geodatabases before loading them into the BLOB.
  • File geodatabases should be compressed and may need to be uncompressed when extracted from the BLOB.
Article ID: 000010947
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
