PROBLEM
Using the 'sdeimport -o create' command to load a raster catalog results in the raster catalog displaying as a polygon feature class. When the same command is used to load a raster dataset, a polygon feature class appears along with the raster.
SDE administration commands do not register items with the geodatabase, so the geodatabase does not properly handle the loaded objects.
Article ID: 000008823
Get help from ArcGIS experts
Download the Esri Support App
