HOW TO
List the ArcSOC.exe processes in PowerShell
First Published: March 13, 2026
Last Published: June 26, 2026
Summary
Use PowerShell to list the ArcSOC.exe processes of dedicated instances with their memory consumption sorted in descending order, along with the name and type of the associated service.
Procedure
From the ArcGIS Server machine:
  1. Run PowerShell as Administrator, right‑click + Shift > Run as administrator as shown in the next image:
  1. Enter / copy the following command, and press Enter:
Get-WmiObject Win32_Process -Filter "name = 'ArcSOC.exe'" | Sort-Object -Property WS -Descending | Select-Object -Property ProcessName,@{Name='WorkingSet (Mo)';Expression={($_.WS/1KB)/1000}}, @{Name='ServiceName';Expression={$_.CommandLine.split("=")[1].split(" ")[0]}}
Example output:
Notes:
  • The WorkingSet (Mo) column shown above corresponds to the Working set (memory) column in Task Manager, shown in the image below.
  • The ServiceName column corresponds to the Command line column in Task Manager below.
This final image shows the generated list and the associated processes in Task Manager.
Article ID: 000040148
Software:
  • ArcGIS Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
