HOW TO
List all the services from ArcGIS Server that are referencing a particular database.
First Published: July 7, 2026
Last Published: July 7, 2026
Summary
When upgrading a database (such as SQL Server), it is critical to stop any dependent services to prevent schema locks and data inconsistency. In environments with hundreds of published services, manually identifying these dependencies is both impractical and error-prone. Furthermore, restarting the entire ArcGIS Server Windows service is often not a viable option due to the unnecessary downtime it causes for unrelated services.
The script below automates this discovery process, providing a targeted list of services that reference a specific database. This allows administrators to perform "surgical" shutdowns, ensuring a smooth upgrade while maintaining high availability for the rest of the site.
Procedure
  1. Import the necessary modules.
    • import arcgis
    • from arcgis.gis import GIS
    • from arcgis.gis import Datastore
    • import arcgis.gis.admin
  2. Specify the credentials to connect to the portal.
    • portal_url = "https://FQDN/webadaptor_instance"
    • username = "portal_username"
    • password = "portaladmin_password"
    • gis = GIS(portal_url, username, password, verify_cert=False)
  3. Get the list of servers federated with ArcGIS Enterprise Portal
    • gis_servers = gis.admin.servers.list()
  4. Specify the server folder in the for loop to list the services inside the folder (for service in server.services.list()) in which the service resides and get the item information. (for example, folder = "Folder_Name". Leaving this blank fetches all services from the ‘siteroot’ folder.
    • for server in gis_servers:
      • for service in server.services.list():
        • mi = service.iteminformation
        • manifest1 = mi.manifest["resources"][0]["onPremisePath"]
        • manifest2 = mi.manifest["databases"][0]["onPremiseConnectionString"]
  5. Print all services that are published from the specified database name.
    • if ("DATABASE=Database_name") in manifest2:
      • print(service.properties.serviceName, service.properties.type)
      • print(manifest2)
Here is the result after running the above script:
import arcgis
			print(manifest2)
Alyssa_Data_1 MapServer
BoundaryAll MapServer
cities MapServer
Defect MapServer
Report_Notes_Attacgment_Table2 MapServer
ReportNotes_Table1 MapServer
Shawn_Krittika_Testing MapServer
Article ID: 000040862
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
