PROBLEM
You used the ArcMap Insert Menu Object dialog to link to a Word document. Then you saved the map document and closed ArcMap. After making changes to the linked Word document, you reopen your saved map document, but the linked document does not reflect your changes.
ArcMap doesn’t automatically update the cached representation when documents are loaded.
Article ID:000003052
Get help from ArcGIS experts
Download the Esri Support App
