PROBLEM
Lines draw between polygons when viewing PDFs exported from ArcMap
First Published: May 5, 2016
Polygons with no outline draw with fine outlines when exported to Portable Document (PDF), Adobe Illustrator (AI), or Encapsulated PostScript (EPS) formats from ArcMap and viewed in Adobe applications.
[O-Image] Example of lines drawing between polygons in PDF
Cause
This is a known issue because of how PostScript entities, such as PDF, are drawn on the screen in such applications as Adobe Reader, Illustrator, etc. Unless the data is topologically correct with true shared edges, fine lines may be visible between polygons when viewing ArcMap exported files in the format of PDF, AI, or EPS in such applications as Adobe Reader, Illustrator, etc.
However, the print out of the exported ArcMap documents in PDF, AI, and EPS do not show these lines.
Solution or Workaround
· Ignore these lines.
· Use topographically accurate data that has true shared edges.
    Article ID: 000008913
    Software:
    • ArcMap
    Get support with AI
    Start chatting now
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
