HOW TO
Limit the results of the Search widget to a specific extent in Web AppBuilder for ArcGIS
First Published: January 23, 2018
Summary
The results of the Search widget can be limited to a certain extent in Web AppBuilder for ArcGIS by editing the config_Search.json file in [install dir]\server\[app#]\configs, and the Widget.js file in [install Dir]\server\apps\[app #]\widgets\Search.
Procedure
The following code segments demonstrate how to limit the results of the Search widget to a specific extent.
Add the searchExtent variables, consisting of the minimum and maximum x- and y- coordinates, as follows:
"type": "locator",
      "searchExtent": {
        "xmin": -9589858.361942431,
        "ymin": 3964964.109405532,
        "xmax": -9522593.777051566,
        "ymax": 4031693.635098401,
        "spatialReference": {
          "wkid": 102100
Following the code above, Extent is now required in the require list in the beginning of the script.
require([
   'esri/geometry/Extent',
   function()
The variables added in the config_Search.json file are then retrieved in the Widget.js file in [install Dir]\server\apps\[app #]\widgets\Search to create a new Extent object, referring to the minimum and maximum x- and y- coordinates set in the config_Search.json file.
if (source && source.url && source.type === 'locator') {
              locator: new Locator(source.url || ""),
              outFields: ["*"],
              singleLineFieldName: source.singleLineFieldName || "",
              name: source.name || "",
              placeholder: source.placeholder || "",
              countryCode: source.countryCode || "",
              maxResults: source.maxResults || 6
            if(source.searchExtent){
              locSource.searchExtent =  new Extent(source.searchExtent);
            return locSource;
Article ID: 000014969
Software:
  • ArcGIS Web AppBuilder
  • ArcGIS API for JavaScript
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
