HOW TO
The ability to disable editing a web map is possible using JavaScript by implementing the drawToolbar.deactivate() and editToolbar.deactivate() functions in a script.
To set a certain number of allowable edits in a web map configured using ArcGIS API for JavaScript before editing is disabled, the script requires a counter with a preset number that triggers the deactivate function when the counter reaches the specified number.
//Set up the counter for graphic added
count = count + 1;
console.log("Graphic Count", count);
//Editing is enabled for 3 or less edit points
if(count <= 3) {
appliedEdits = selectedTemplate.featureLayer.applyEdits([newGraphic], null, null);
else
drawToolbar.deactivate();
editToolbar.deactivate();
alert(" You have successfully completed 3 edits!");
return count;
Note: Edit the code segment, "if(count <= 3)" with the desired number of edits allowed.
Article ID: 000014900
Get help from ArcGIS experts
Start chatting now
