HOW TO
License ArcGIS Server when FME Flow is reading or writing directly to an enterprise geodatabase
First Published: June 1, 2026
Last Published: June 1, 2026
Summary
FME Flow must use ArcGIS Enterprise software for any Esri binary format support, such as file, mobile, or enterprise geodatabases or Knowledge Graph. ArcGIS Knowledge in ArcGIS Enterprise requires ArcGIS Server Standard as the minimum requirement. ArcGIS Server Basic is sufficient for enterprise, file, and mobile geodatabase support and must be licensed for all cores on machines running FME engines that call ArcGIS executables. You may virtualize the cores on a machine to tune the core count to your actual requirements. For more information, refer to pages 4 and 5 in Licensing ArcGIS Enterprise Deployments in Virtualized and Cloud Environments.
Procedure
FME Flow can write to an enterprise geodatabase without a local ArcGIS Enterprise installation if meets the following requirements.
  • The target feature class or table is published by reference from a registered data store.
  • FME Flow has the Esri ArcGIS Connector package installed and uses an Enterprise feature service reader/writer.
This approach uses REST calls, not an Esri executable. For more information, refer to FME Support Center: Connecting to Esri Applications from FME Flow without a license.
ArcGIS Pro is licensed as a single-user app and may not be used on an FME Flow machine to enable Esri formats.
Article ID: 000042057
Software:
  • ArcGIS Server
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
