Solution or Workaround
Summary
On Solaris 2.5, 2.5.1, 2.6, typing the ARC HELP command returns this message:
ld.so.1: /esri/hh_solaris2/bin/hyperhelp: fatal: libXm.so.3: can't open file:
errno=2
Cause
The path to the libXm.so.3 library is not included in the LD_LIBRARY_PATH environment variable.
Solution
1. Edit the LD_LIBRARY_PATH environment variable in the your .cshrc file to include the '/usr/dt/lib' path. The setenv line should look like this:
setenv LD_LIBRARY_PATH $ARCHOME/lib:/usr/lib:/usr/openwin/lib:/usr/dt/lib
2. Source your .cshrc file
Code:
unix%>source ~/.cshrc
ArcDoc will start properly.
See ArcDoc 7.2.1 under Contents > Troubleshooting > Frequently Asked Questions > ArcDoc.
