PROBLEM
In ArcGIS GeoBIM for ArcGIS Enterprise 11.3 and 11.4, with Autodesk Platform Services (APS) applications created on or after December 10, 2024, a “Legacy endpoint is deprecated” error is returned when using the Locate Engineering Documents tool.
ArcGIS GeoBIM on ArcGIS Enterprise configured with Autodesk Platform Services (APS) applications created on or after December 10, 2024 will fail to generate document geometries in the Tools page with “DA job failed” error for all documents due, to deprecation of certain APS APIs.
An example error message in the error log may appear as follows:
{\"reason\":\"Legacy endpoint is deprecated\"}\r\n[01/14/2025 03:40:43] Error: Unable to download file from https://developer.api.autodesk.com/oss/v2/buckets/...,O2tenant.179: Response status code does not indicate success: 403 (Forbidden)..\r\n[01/14/2025 03:40:43] Error: Response status code does not indicate success: 403 (Forbidden).\r\n[01/14/2025 03:40:43] Error: An unexpected error happened during phase Downloading of job.\r\n[01/14/2025 03:40:43] Job finished with result FailedDownload\r\n[01/14/2025 03:40:43] Job Status:\r\n{\r\n \"status\": \"failedDownload\",\r\n \"reportUrl\": \"https://dasprod-store.s3.amazonaws.com/workItem/....","type":"error","message":"DA job failed for: YourFile.dwg","objectId":8}
This issue is related to the deprecation of one of the Autodesk APIs that affects new APS applications created on or after December 10, 2024.
Publish the new ArcGIS GeoBIM geoprocessing service using the updated service definition (.sd) file to replace Autodesk Platform Services (APS) APIs that have been deprecated.
Article ID: 000034768
Get help from ArcGIS experts
Start chatting now
