PROBLEM
*This issue has been resolved in ArcIMS 9.0.1*
Layout exported to a vector format of PDF, EPS, EMF, or AI may be incorrect due to the following reasons:
� The symbology of point, line and polygon features in the export layout is different from the original map.
� Layout is empty when map contains a raster.
� ArcMap server may crash when a layout is exported.
Vector layout export does not work correctly. This is a known limitation with ArcMap server on Solaris in ArcIMS 9.0.
Article ID:000006889
Get help from ArcGIS experts
Download the Esri Support App
