PROBLEM
Layers with special characters are not included in a multi-layer cache
After creating a multi-layer cache for an ArcGIS Server map service, layers that include special characters in their names, such as /, &, %, @, etc., do not appear when the service is added to the client application. In the arcgiscache directory for that service, the layer is not listed among the directories.
Cause
The cache tiles are accessed by way of a virtual directory, and the directories are named after the layers. The virtual directory path is invalid if the layer name contains special characters. As a result, that layer's cache will not be created.
Solution or Workaround
Remove special characters from layer names, such as /, &, %, @, etc.
    Article ID: 000010005
    Software:
    • ArcGIS Server
    Get support with AI
    Start chatting now
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
