PROBLEM
Layers fail to draw when attempting to add a shapefile to ArcMap
First Published: May 6, 2016
When attempting to add a shapefile to ArcMap, the layer fails to draw and the following error is returned:
Error:
 "One or more layers failed to draw. There was a problem drawing the shapefile. Drawing aborted."
This is a generic error. There are several reasons associated with this issue. Refer to the Related Information section for more information and other causes for this error.
Cause
This issue may occur when:
  • The data file is corrupted
  • The shapefile is in a ZIP file and is not extracted
  • The shapefile is larger than the 2GB maximum
Solution or Workaround
Below are some ways to resolve this issue.
Ensure the existing file is not corrupted.
  1. Use the Check Geometry tool to identify the geometry issues: ArcToolbox > Data Management Tools > Features > Check Geometry. For more information, refer to the following link: Check Geometry.
  2. Use the Repair Geometry tool to fix the issues identified in the Check Geometry toolArcToolbox > Data Management Tools > Features > Repair Geometry. For more information, refer to the following link: Repair Geometry.
Alternatively, export the data from the Catalog window instead of dragging the data to the data frame. For more information, refer to the following link: Exporting features.
If using a ZIP file as the input shapefile, ensure the ZIP file is extracted before adding the shapefile. For more information, refer to the following link: Choosing an export file type.
Article ID: 000012879
Software:
  • ArcMap
Get support with AI
Start chatting now
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
