PROBLEM
Labels may shift location during conversion to annotation
First Published: May 5, 2016
When converting labels to annotation at a zoomed in extent, the placement of the annotation may be different than the original location of the labels. This behavior is common when annotating polyline feature classes, but may also occur with the other feature class types.
Cause
This is by design. Unlike the 'Label Features' command, 'Convert Labels to Annotation' accounts for the extent of the entire dataset when making the conversion. The 'Label Features' command places labels according to the extent of the data view. When converting labels to annotation, the labels may be moved for better placement within the scope of the entire map, rather than merely the extent displayed within the data view.
Solution or Workaround
To avoid this behavior only create annotation for features shown within the current data view extent.
  1. Right-click the layer in the ArcMap Table of Contents.
  2. Select 'Convert Labels to Annotation'.
  3. From the 'Convert Labels to Annotation' dialog box, set the option 'Create Annotation for:' to 'Features displayed within the current extent'.
Article ID: 000005551
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
