PROBLEM
Labels disappear when using line callouts
First Published: May 5, 2016
When using dynamic labels with Simple Line Callouts, labels erratically appear or disappear.
Cause
Though the problem may appear as you are setting or clearing a reference scale or while zooming in or out on the map, it has nothing to do with either. The problem is that the Simple Line Callout is not very reliable when used with dynamic labels.
Solution or Workaround
Use a Line Callout, but adjust the gap distance as needed and turn off the Accent Bar and Border options when creating dynamic labels.
Article ID: 000005172
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
