HOW TO
Instructions provided describe how to label expressions by way of VBScript. ArcMap provides a way to programmatically define the text that displays when labeling features.
This article contains sample code that show how to perform these common functions: case formatting, extracting a number, and stacking of labels.
Note: The content in this article pertains to ArcGIS versions 8.x and 9.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Code: Function FindLabel ( [NAME] ) ' Converts [NAME] to Mixed Case ' ----------------------------- Dim t, newS, i t = [NAME] newS = UCase(Mid(t, 1, 1)) 'Upcase 1st char i = 2 Do While i <= Len(t) ' check if previous char is a space If InStr(1, Mid(t, i - 1, 1), " ", vbTextCompare) > 0 Then ' space found newS = newS & UCase(Mid(t, i, 1)) Else newS = newS & LCase(Mid(t, i, 1)) End If i = i + 1 Loop FindLabel = newS End Function
Code: Function FindLabel ( [NAME] ) ' Extracts number from [NAME] ' --------------------------- Dim sIn, sNew, i sIn = [NAME] ' input field value sNew = "" 'result i = 1 ' check if char is numeric While i <= Len(sIn) If IsNumeric(Mid(sIn, i, 1)) Then sNew = sNew & (Mid(sIn, i, 1)) End If i = i + 1 Wend FindLabel = sNew End Function
Code: Function FindLabel ( [NAME] ) ' Stacks a label in multiple lines if ' exceeding a given length. ' Note: Not applicable to line layers. ' ------------------------------------ dim s, sNew, i, l s = [NAME] l = Len(s) if l > 10 then ' stack if exceeding this length sNew = Left(s,10) i = 11 ' scan for blank space starting from this position While i <= l if Mid(s,i,1) = " " then sNew = sNew & VBNewLine else sNew = sNew & Mid(s,i,1) end if i = i + 1 Wend else sNew = s end if FindLabel = sNew End Function
Note: For more information, refer to the ArcGIS Desktop help topics: Labeling, Specifying text.
Article ID:000004291
Get help from ArcGIS experts
Download the Esri Support App
