BUG
After upgrading to ArcGIS GIS Server 10.5, joining additional machines to an ArcGIS Server site (single or multi-node) using a network path for the configuration store fails with the following error:
Error: Unable to access directory path '/relational-datastore-types' on the shared config-store.
This issue occurs in the following cases:
This issue does not occur in the following cases:
The host ArcGIS Server site is upgraded to ArcGIS 10.5 from an earlier version. ArcGIS Server searches for a path to the /relational-datastore-types folder, which is unintentionally added to the configuration store path in ArcGIS Server 10.5. This folder is not in the configuration store root path for newer versions.
Note: This issue does not occur when upgrading from an earlier version to ArcGIS Server 10.5.1 or newer.
...\arcgisserver\config-store\'relational-datastore-types
Note: It is recommended to delete the relational-datastore-types folder before upgrading to ArcGIS Server 10.5.1 or later from ArcGIS for Server 10.5 to ensure there is no extra folder left in ArcGIS 10.5.1 or later releases.
Article ID: 000016187
Get help from ArcGIS experts
Start chatting now
