PROBLEM
Join data is absent in a portion or the entire resulting joined dataset
A join of two datasets completes, but values are missing from either a portion or the entire resulting dataset.
For example, when joining a shapefile to a dbf table, the join completes in such a manner that the field names of the dbf are appended to the shapefile, but the dbf portion of the resulting join shapefile doesn't have data in the cells.
Cause
Possible causes:
· A shapefile name may begin with a number.
· The file name or its path contains space characters, especially with dbf files.
· A field name in one or both files contains an invalid character, such as a slash, space character, parenthesis, and so forth.
Solution or Workaround
Remove the invalid characters, or rename the file or fields causing the problem.
Article ID: 000004854
Software:
  • ArcMap 8 x
  • ArcMap 9 x
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
