ERROR
When compiling or executing a Java application that uses the ArcObjects Java API, the following error is returned:
java.lang.UnsatisfiedLinkError: no ntvinv in java.library.path
The PATH variable does not include a directory which contains the native libraries required for ArcObjects Java classes to function.
$ARCENGINEHOME may need to be replaced with the location of the ArcGIS SDK installation.
Article ID:000007942
Get help from ArcGIS experts
Download the Esri Support App
