BUG
Java Globe Animation samples fail to run on certain Linux operating systems
Globe Animation Java samples fail to run on certain Linux operating systems. This has been seen after updating GNOME.
Cause
The crash is occurring because of a symbol conflict between an ArcGIS library and the Linux libz.so library.
Workaround
The problem typically occurs when logged in locally to the Linux machine.
Using 'rlogin' to re-log into the local machine as a remote user usually avoids the problem.
The planned fix for this problem involves a tighter way of linking the ArcGIS libzn.so library. This prevents ArcGIS internal calls from being intercepted by the Linux operating system.
This fix is planned to be included in a 9.3.1 service pack.
Article ID: 000010611
Software:
  • ArcGIS Engine
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
