BUG
ArcGIS Server Java ADF Buffer Template fails with an exception if the server object only has images as its data source. This failure of the Buffer Template also applies to server objects that only have WMS layers as their data source.
The Buffer Template fails because the application's dropdown lists are unable to populate field values for image data sources.
Article ID:000007503
Get help from ArcGIS experts
Download the Esri Support App
