PROBLEM
IZonalOp::ZonalStatistics fails when both a string field and a selection are used in RasterDescriptor
When calling the IZonalOp::ZonalStatistics method, if the zone is defined by a RasterDescriptor in which both a selection and a string field are used, the operation fails.
Cause
This is a known issue with ArcGIS 8.1.
Solution or Workaround
There are two solutions for this problem:
  • Convert the zone raster into a feature class using the Conversion function in the Spatial Analyst user interface. Then, create a FeatureDescriptor from the feature class just created, and pass the FeatureDescriptor to the operator.
  • Do the conversion and creation as two steps in VB code. First do a conversion with the selection using IConversionOp::ToRasterDataset. Next, create a RasterDescriptor using the output from the conversion with the string field only.
Article ID:000003471
Software:
  • ArcMap 8 x
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
