Frequently asked question
Note: ArcSDE software, including the application server, command tools, and SDK with C and Java APIs, was deprecated at ArcGIS 10.2.2 and is no longer distributed.
Here is an example of DBTUNE settings that could be used when loading data by way of ArcSDE into Oracle Spatial format.
Note the following:
##SDO_TAS ATTRIBUTE_BINARY "LONGRAW" GEOMETRY_STORAGE "SDO_GEOMETRY" A_INDEX_ROWID "TABLESPACE SDE_IDX NOLOGGING PCTFREE 10 INITRANS 4" A_INDEX_SHAPE "TABLESPACE SDE_IDX NOLOGGING PCTFREE 10 INITRANS 4" A_INDEX_STATEID "TABLESPACE SDE_IDX NOLOGGING PCTFREE 10 INITRANS 4" A_INDEX_USER "TABLESPACE SDE_IDX NOLOGGING PCTFREE 10 INITRANS 4" A_STORAGE "TABLESPACE SDE_DATA PCTFREE 10 PCTUSED 90 INITRANS 4" B_INDEX_ROWID "TABLESPACE SDE_IDX NOLOGGING PCTFREE 10 INITRANS 4" B_INDEX_SHAPE "TABLESPACE SDE_IDX NOLOGGING PCTFREE 10 INITRANS 4" B_INDEX_USER "TABLESPACE SDE_IDX NOLOGGING PCTFREE 10 INITRANS 4" B_STORAGE "TABLESPACE SDE_DATA PCTFREE 10 PCTUSED 90 INITRANS 4" D_INDEX_DELETED_AT "TABLESPACE SDE_IDX NOLOGGING PCTFREE 10 INITRANS 4" D_INDEX_STATE_ROWID "TABLESPACE SDE_IDX NOLOGGING PCTFREE 10 INITRANS 4" D_STORAGE "TABLESPACE SDE_DATA PCTFREE 10 PCTUSED 90 INITRANS 4" SDO_COMMIT_INTERVAL 500 SDO_DIMNAME_1 "X" SDO_DIMNAME_2 "Y" SDO_INDEX "RTREE" SDO_INDEX_SHAPE "tablespace=SDE_SP_IDX" SDO_LB_1 0.000000 SDO_LB_2 5000000.000000 SDO_SRID 81936 SDO_TOLERANCE_1 0.000500000000 SDO_TOLERANCE_2 0.000500000000 SDO_UB_1 1000000.000000 SDO_UB_2 6000000.000000 SDO_VERIFY "TRUE" END
Note: As of the ArcSDE 9.x releases, the SDO_VERIFY parameter in any DBTUNE keyword is now obsolete and cannot be used.
Article ID:000005646
Get help from ArcGIS experts
Download the Esri Support App
