Is it possible to turn off the grey globe with 3D view in ArcGIS Pro?
First Published: May 5, 2016
No, it is not possible to turn off the grey globe with 3D view in ArcGIS Pro because the grey globe is considered as the reference layer; removing the grey globe leaves the project without a reference layer. In a case where feature classes with negative elevations are present, and the feature is invisible, follow the procedure in the following article, Problem: The elevation surface in a 3D scene blocks some features
Article ID: 000012586
Software:
ArcGIS Pro
Get support with AI
