Frequently asked question
It is possible to print customTextElement by using the PrintTemplate() method in ArcGIS API for JavaScript. The customTextElement parameter is an array of name-value pairs required if a user wants to update text of a TextElement, which is not a DynamicText on the page layout. The values of customTextElement must be of type string.
The following code snippet describes how to print customTextElement using JavaScript:
var plate = new PrintTemplate();
plate.layout = plate.label = ch;
plate.format = "PDF";
plate.layoutOptions = {
"authorText": "Made by: Esri's JS API Team",
"copyrightText": "<copyright info here>",
"legendLayers": [],
"titleText": "Pool Permits",
"scalebarUnit": "Miles",
"customTextElement": [{"<textElementName1>" : "<value1>"}]
Article ID: 000014409
Get help from ArcGIS experts
Start chatting now
