Frequently asked question
Is it possible to export a map service as a shapefile in ArcMap?
First Published: May 5, 2016
This article applies to retired ArcGIS versions 10.2.x. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
No, it is not possible to directly export an ArcGIS for Server map service to a shapefile in ArcMap. Map services must initially have a Geoprocessing capability enabled, and have access granted to various tools and frameworks that allow analysis and management of geographic data.
However, users can add the map service into ArcMap and use the Distributed Geodatabase toolbar to extract data from the service. This works if the map service is enabled with Geodata Access from the capabilities list when the map service is published. The 'Extract Data' option is enabled when a valid service is added to ArcMap.
Article ID: 000012476
Software:
  • ArcGIS Server
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
