Is it possible to export a geodatabase schema to a UML object model?
Last Published: April 26, 2020
No; a geodatabase schema can be created from a UML object model using the schema wizard in ArcCatalog. It is not possible, however, to reverse-engineer a UML object model from a geodatabase schema.
Article ID: 000012741
Software:
ArcMap
Get support with AI
