Frequently asked question
Is it possible to directly georeference a PDF file in ArcMap?
No, it is not possible to georeference a PDF file directly in ArcMap. ArcGIS does not support PDF as an input format. The PDF file must be converted to a supported raster format, such as JPEG or TIFF, and be added to ArcMap before georeferencing.
Converting the PDF file to a supported raster format can either be done by:
  • Scanning the PDF document.
  • Taking a screenshot of the PDF file.
  • Using an online conversion tool.
  • Using the 'PDF to TIFF' tool.
In earlier versions of ArcGIS, the 'PDF to TIFF' tool is only available with the Production Mapping extension. In ArcGIS 10.3, the tool is located under Conversion Tools > From PDF.
Article ID: 000012398
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
