Frequently asked question
Is a raster projected on-the-fly if a different spatial ref. is set when loading it into a gdb?
Answer
When loading a raster dataset into a geodatabase, you can specify a spatial reference that may be different from that of the raster dataset. However, projection-on-the-fly will not be applied to the raster because only the raw pixel data is used when loading into a geodatabase.
You could write a customized application that uses the Raster::SaveAs method to save the raster to another dataset. This will resample the original data and apply the transformation to the pixel data. Load the resulting output raster dataset, which will be in the desired projection, into the geodatabase.
Article ID:000003161
Software:
  • ArcMap 8 x
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
