Frequently asked question
Is a geodatabase upgrade necessary after installing ArcGIS 10 Service Pack 2?
After installing ArcGIS 10 (Desktop, Engine, Server) Service Pack 2, the Upgrade Geodatabase command on the geodatabase property page is enabled and the Upgrade Geodatabase geoprocessing tool can be run.
The Upgrade Geodatabase command and geoprocessing tool are enabled when either the geodatabase system tables or geodatabase stored procedures require upgrading.
ArcGIS 10 SP2 enterprise geodatabases running on the following DBMS platforms require upgrading, as SP2 contains changes to the geodatabase stored procedures for these platforms:
▪ Oracle
▪ SQL Server
▪ Informix
▪ DB2
Enterprise geodatabases running on PostgreSQL do not require an upgrade with ArcGIS 10 SP2.
Article ID: 000011261
Software:
  • Legacy Products
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
