ERROR
"Invalid redirect URI" when setting up ArcGIS Enterprise connector in Power Automate
Last Published: June 24, 2024
Error Message
When following the documentation to set up the ArcGIS Enterprise connector in Microsoft Power Automate, upon signing into ArcGIS Enterprise from Microsoft Power Automate users may receive the following error message:
Cause
In step 5 under Get information for the connector, the documentation mentions that the following redirect URIs should be listed with the application:
  • urn:ietf:wg:oauth:2.0:oob
  • https://global.consent.azure-apim.net/redirect
However, the redirect URI used by Microsoft Power Automate may also be as follows:
https://global.consent.azure-apihub.us/redirect/arcgisenterprise
Solution or Workaround
Add the correct redirect URI to the application in Portal for ArcGIS:
Article ID: 000032012
Software:
  • ArcGIS Enterprise
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
