ERROR
The VBScript CreateObject (FileSystemObject) works fine on a PC, but returns
"Invalid object"
on a Windows CE device.
There is no FileSystemObject available for CE.
Use the File object from the ArcPad object model.
The File object provides platform independent file access, so the same code will work on a PC or CE device. Unless an ArcPad application is being developed explicitly for a PC environment, developers should always use the ArcPad File object. Embedded VB has a File object, but it is only available if an embedded VB application that has a reference to this control is installed.
Article ID:000005432
Get help from ArcGIS experts
Download the Esri Support App
