ERROR
Internal Error 2755.1612 while installing ArcGIS 9.x
Error Message
While installing ArcGIS 9.x, the following error displays:
"Internal Error 2755.1612: could not find file C:\winnt\Installer\48675.msi"
The number at the end may vary.
Cause
The patch installation was started from a mapped drive or other removable source. This is a known problem with Windows Installer patches.
Solution or Workaround
Copy the patch file to a local hard drive, such as C:, and run the install from that location.
    Article ID: 000008374
    Software:
    • ArcMap
    Get support with AI
    Start chatting now
    Discover more on this topic
    Get help from ArcGIS experts
    Contact technical support
    Start chatting now
    Go to download options
