PROBLEM
Installing Portal for ArcGIS 11.1 in long form directories
Last Published: January 30, 2024
When performing a new installation or upgrade to Portal for ArcGIS 11.1 with an installation folder with a name greater than 34 characters, the installation process doesn’t produce any errors, however, the Portal service is not created.  Portal for ArcGIS will be missing from the Service Manager.
The attached MST file can be applied to install (including upgrade) Portal for ArcGIS to an installation folder with a name greater than 34 characters.
Cause
Solution or Workaround
The transform file (portal1.mst) is applied during the installation of Portal for ArcGIS 11.1 as follows:
[path to Portal 11.1 setup.exe] ACCEPTEULA=yes TRANSFORMS=[path to the transform file]\portal1.mst
Example:
\\Setuparchive\11.1\Portal\Setup.exe ACCEPTEULA=yes TRANSFORMS=\\Setuparchive\11.1\Portal\portal1.mst
Any other installation values can also be supplied in the command.  Running the command as shown above installs in full user interface, allowing other values to be confirmed during the upgrade.
Article ID: 000031202
Software:
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
