PROBLEM
Installing ArcGIS Solutions in a high availability configuration of ArcGIS Enterprise, the ArcGIS Solutions gallery is empty
Last Published: March 4, 2022
When ArcGIS Solutions for ArcGIS Enterprise is installed in a high availability configuration of ArcGIS Enterprise, the ArcGIS Solutions gallery appears empty.
ArcGIS Solutions for ArcGIS Enterprise is only available for install on ArcGIS Enterprise 10.9 and 10.9.1 (Windows, Linux).
Cause
This is a known issue in a high availability configuration of ArcGIS Enterprise, and is associated with a known defect, BUG-000147009.
Solution or Workaround
Currently, there is no workaround for this issue.  If you are experiencing this problem, please contact Esri Technical Support.
Article ID: 000027317
Software:
  • Portal for ArcGIS
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
