PROBLEM
Installation of ArcGIS Desktop 'freezes' on rastersde8x.dll
First Published: May 5, 2016
Last Published: January 4, 2021
When installing ArcGIS, the installation may 'freeze' or stop responding while registering the file rastersde8x.dll.
This article pertains to ArcGIS versions 9.x only. Later versions of ArcGIS may contain different functionality, as well as different names and locations for menus, commands and geoprocessing tools.
Cause
There are conflicting entries present in the registry.
Solution or Workaround
After removing any ArcGIS products, and before attempting to install ArcGIS, remove the conflicting Raster entries in the registry.
  1. Open regedit by way of Start > Run; type 'regedit'.
  2. Browse to HKEY_LOCAL_MACHINE\Software\ESRI\
  3. Delete the \Raster hive. This removes the conflicting registry entries.
  4. Reinstall ArcGIS normally. The problem should no longer occur.
Article ID: 000008146
Software:
  • ArcMap
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
