HOW TO
This article shows how to install ArcIMS 3.1.
The setup program looks for a specific registry entry to determine if JRE is installed. JDK 1.3 does not create the registry entry, even though it contains a valid JRE. If the JRE is installed, click Browse to navigate to its location.
If you are setting up a Web site, or a multiple ArcIMS Spatial Server configuration, you must include the domain name, such as esri.esri.com. If your Web server has a port number, other than the default HTTP port(80), use this syntax: webservername:port number. For example: esri.esri.com:81.
If you accept the default, after the installation you must create virtual directories for the output and Web site (see Step 10). These directories are not required if you select a new location for the output directory.
The ArcIMS Spatial Server, Moniter, and Tasker communicate with the ArcIMS Application Server via the Registry port. The Servlet Connecter and ArcIMs Application Server communicate via the conector port.
If you don't know the location of the servlet directory, click Help for a list of the most common servlet directory locations. If you are not sure, use this location <ArcIMS Installation Directory>\Connectors\Servlet, and contact your system administrator. The servlet connector must be moved from this directory to the proper Web server directory before using ArcIMS.
The User Name and Password must be for the installation account and have administrator privileges. This information gives ArcIMS the ability to start Windows services and gives the ArcIMS Spatial Server the necessary privileges to access resources on the local computer or network.
This information is written to <ArcIMS Installation Directory>\Common\InstallSummary.log after the installation.
Microsoft Java Virtual Memory 3186, or later, is required for the ArcIMS Windows Services. The installation prompts you to update your system if Microsoft Java Virtual Memory is not detected, or if you have an older version.
This file lets the system administrator know which ports are in use so they will not be duplicated. This information is written to the summary log file <ArcIMS Installation Directory>\Common.
Article ID:000004821
Get help from ArcGIS experts
Download the Esri Support App
