HOW TO
In some cases, there may be a need to insert geometries into a feature class using structured query language (SQL). This can be done using a loop or a database cursor in SQL. Sometimes, due to performance, resources, or workflows, creating data via SQL is preferable to creating the data in ArcMap.
-- Get the number of rows in the looping table
DECLARE @RowCount INT
SET @RowCount = (SELECT COUNT(*) FROM sde.INPUT_TABLE)
-- Declare an iterator
DECLARE @iterator INT
-- Initialize the iterator
SELECT @iterator = MIN(OBJECTID) FROM SDE.INPUT_TABLE
-- Loop through the rows of a table @myTable
WHILE @iterator is NOT NULL
BEGIN
DECLARE @id as integer
EXEC sde.next_rowid 'sde', 'points', @id OUTPUT;
INSERT INTO sde.POINTS (OBJECTID, Shape)
SELECT
@id,
geometry::STPointFromText('POINT('+str(POINT_X, 38, 8) + ' ' + str(POINT_Y, 38, 8) + ')', 2286) as SHAPE
FROM sde.INPUT_TABLE where objectid = @iterator;
SELECT @iterator= MIN(OBJECTID) FROM SDE.INPUT_TABLE WHERE @iterator < @RowCount
END
In the example below, point geometry is inserted into a feature class from an existing database table.
Note: This procedure works best if a unique identifier column exists in the input database table, such as a rownum or OID field in SQL Server. This ensures the WHILE loop does not miss any rows that are not unique.
Note: To insert data into a registered feature class, a unique, not-null value must be specified for the ObjectID column. To do this, the Next_RowID procedure must be used.SQL Server Geometry sample:
SET @RowCount = (SELECT COUNT(*)FROM sde.INPUT_TABLE)
BEGIN
SELECT @id,
END
Oracle SDO Geometry sample:
SET SERVEROUTPUT ON
-- Declare a cursor
DECLARE
CURSOR points is
select *
from sde.input_table;
--Loop through the cursor
BEGIN
FOR pt IN points LOOP
INSERT INTO SDE.POINTS (OBJECTID, SHAPE) VALUES (
sde.gdb_util.next_rowid('sde', 'points'),
MDSYS.SDO_GEOMETRY(2001,2286,MDSYS.SDO_POINT_TYPE(pt.point_x, pt.point_y,NULL),NULL,NULL)
END LOOP;
COMMIT;
END;
Oracle ST Geometry sample:
SET SERVEROUTPUT ON
-- Declare a cursor
DECLARE
CURSOR points is
select *
BEGIN
sde.ST_Point(pt.point_x,pt.point_y, 2286)
END LOOP;
COMMIT;
END;
Article ID: 000012317
Get help from ArcGIS experts
Start chatting now
