PROBLEM
ArcGIS Online web map with floor filtering enabled no longer displays certain units
First Published: October 6, 2025
Last Published: October 6, 2025
ArcGIS Online web map with floor filtering enabled no longer displays certain units of a hosted feature layer view. This only affects hosted feature layer views, the issue does not occur when the respective hosted feature layer that the view is made from is added to a web map with floor filtering enabled.
Cause
The max record count of a specific layer is less than the number of features in the layer.
Solution or Workaround
Re-creating the view or editing the max record count resovles the issue.
Article ID: 000033027
Software:
  • ArcGIS Online
Get support with AI
Start chatting now
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
