HOW TO
Increase performance when viewing images
Summary
How can I increase performance when viewing images in ArcIMS?
Procedure
  • On Windows NT, choose Start > Settings > Control Panel and double-click System.
    Click the Environment tab.
    In the system variable window, click PATH (or create it if it doesn’t already exist) and add: ;<drive>:\Program Files\Javasoft\Jre\1.3.0_02\bin
    Click OK and close the Control Panel window.
  • On Windows 2000, choose Start > Settings > Control Panel and double-click System.
    Click the Advanced tab.
    Click Environment Variables.
    In the System Variable window, click your system variable PATH, click Edit and add: ;<drive>:\Program Files\javasoft\jre\1.3.0_02\bin
  • On UNIX, use the following settings:
    setenv LD_LIBRARY_PATH $AEJHOME/lib for ArcExplorer-Java Edition
    setenv LD_LIBRARY_PATH $AIMSHOME/lib for ArcIMS Author
    This allows your system to take advantage of the Java Advanced Imaging (JAI) libraries to increase performance.
    NOTE: ArcIMS for IBM AIX and HP-UX does not support JAI. When loading a TIFF image in ArcIMS Author or ArcExplorer-Java Edition, you will receive a warning message: "Could not load mediaLib" in the Message Console. This is just a warning message indicating that the JAI library cannot be loaded.
Article ID:000003434
Software:
  • Legacy Products
Download the Esri Support App
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Go to download options
