BUG
It is possible to receive incorrect results when executing a SQL statement that uses the sde.st_disjoint operator.
For example, the following query should return one row (the street that is disjoint from the input lake but its shape's envelope intersects the specified input envelope), but no rows are returned in the result set.
Code:
SQL> SELECT roads.street_name
2 FROM roads, lakes
3 WHERE lakes.name = 'Jenks Lake'
4 AND sde.st_disjoint(roads.shape, lakes.shape) = 1
5 AND sde.st_envintersects(roads.shape,-114.4,32.7,-113.6,33.4) = 1;
no rows selected
Oracle's optimizer chooses to use the sde.st_spatial_index as the access path instead of applying the operator as a filter.
In the example using st_disjoint with the roads and lakes table, the Oracle optimizer selected the spatial index as the access path using the lake (where lakes.name = 'Jenks Lake') as the input geometry to search the roads spatial index. Since no rows were returned from the roads spatial index, there were no candidate rows to meet the st_envintersects operator.
If the optimizer applies the st_disjoint operator as a filter in the SQL statement, then every road's shape envelope that intersects the input envelope in st_envintersects would be passed as input geometries to the st_disjoint operator, and therefore return the correct result.
Code:
ALTER INDEXTYPE sde.st_spatial_index
2 DROP st_disjoint (sde.st_geometry, sde.st_geometry);
Article ID:000010057
Get help from ArcGIS experts
Download the Esri Support App
