ERROR
Incorrect Command Line Parameters
First Published: May 5, 2016
Error Message
When starting the installation of ArcGIS, the following error is reported by the Windows Installer:
"Incorrect Command Line Parameters.
Windows Installer. V 1.10.1029.1
Copyright 1999 Microsoft Corporation. All rights reserved.
Portions of this software are based in part on the work of the Independent JPEG Group"
Cause
There may be a space in the network hostname of the computer.
Solution or Workaround
Contact the network adminstrator to eliminate the space in the computer's hostname or implement the following work-around:
  1. Click Start > Run and enter the following command line parameters into the text box provided and click OK:
    For ArcView Single Use 8.1:
    Code:
    <CD-ROM drive>:\ArcGIS\ArcView.msi LICENSESERVER=<hostname> ESRI_SETUP=ArcGIS
    SEAT_PREFERENCE=Fixed PRODUCTNAME=ArcView DISPLAYNAME=ArcView
    For ArcGIS Desktop 8.1:
    Code:
    <CD-ROM drive>:\ArcGIS\ArcGIS.msi LICENSESERVER=<hostname> ESRI_SETUP=ArcGIS
    SEAT_PREFERENCE=Float PRODUCTNAME=ArcGIS DISPLAYNAME=ArcGIS
    For ArcInfo Workstation 8.1
    Code:
    <CD-ROM drive>:\Workstation.msi LICENSESERVER=<hostname> ESRI_SETUP=ArcGIS
    <CD-ROM drive> refers to the drive letter of your CD-ROM.
    <Hostname> refers to the network hostname of the computer on which you are installing. To check hostname, type hostname at a DOS prompt.
  2. Once the command line parameters are accepted, the installation wizard appears. Continue with the installation as normal.
  3. After the installation is complete, update the registry to properly set up the ArcGIS Desktop Administrator.
    <a href='https://support.esri.com/en/knowledgebase/techarticles/detail/24741' target='_blank'>Problem: ArcGIS Desktop Administrator is not populated</a>
Article ID: 000004191
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
