PROBLEM
When more than one Data Interoperability product is installed on a single machine, there are known issues with the compatibility and functionality of the Data Interoperability installation. Documented in this technical article are a list of install sequences of the Data Interoperability products, the problem that occurs, and the workaround for the issue.
| Installed First | Installed Second | Problem |
| ArcGIS Data Interoperability 10.6 for Desktop | Data Interoperability for ArcGIS Pro 2.1 | ArcGIS Data Interoperability 10.6 for Desktop Quick Import/Export dialog script error in MdDlgContent.htm |
| ArcGIS Data Interoperability 10.6 for Desktop | Data Interoperability for ArcGIS Pro 2.1 | ArcGIS Data Interoperability 10.6 for Desktop Interoperability connections can be created but do not work |
| Data Interoperability for ArcGIS Pro 2.1 | ArcGIS Data Interoperability 10.6 for Desktop | Data Interoperability for ArcGIS Pro 2.1 Quick Import input dataset picker cannot browse |
| Data Interoperability for ArcGIS Pro 2.1 | ArcGIS Data Interoperability 10.6 for Desktop | Data Interoperability for ArcGIS Pro 2.1 Quick Export output dataset picker cannot browse |
| Data Interoperability for ArcGIS Pro 2.1 | ArcGIS Data Interoperability for Server for 10.6 | ArcGIS Data Interoperability for Server for 10.6 fails to publish Spatial ETL tools |
Esri is aware of the underlying cause of these issues and is working to get them fixed.
Until a permanent fix for these issues becomes available, Esri recommends the workaround listed below.
| First / Second | Workaround |
ArcGIS Data Interoperability 10.6 for Desktop / Data Interoperability for ArcGIS Pro 2.1 | Perform a repair install of ArcGIS Data Interoperability 10.6 for Desktop. |
Data Interoperability for ArcGIS Pro 2.1 / ArcGIS Data Interoperability 10.6 for Desktop | Perform a repair install of Data Interoperability for ArcGIS Pro 2.1. |
Data Interoperability for ArcGIS Pro 2.1 / ArcGIS Data Interoperability for Server for 10.6 | No workaround for side-by side-operation exists. Uninstall ArcGIS Data Interoperability for Server 10.6. |
Article ID: 000017667
Get help from ArcGIS experts
Start chatting now
