BUG
Importing an XML workspace document with a geometric network fails with "geometry cannot have Z values"
When importing an XML workspace document into a geodatabase, the import fails with the error:
"Geometry cannot have Z values".
Cause
The XML document was exported using ArcGIS 10 or a later release and contains a geometric network with participating feature classes that are Z-aware.
Workaround
There are two workarounds for this issue:
  • Import the XML workspace document using a pre-10 version of ArcGIS. If the information within the document needs to be in another geodatabase, use Copy/Paste to move the data to other geodatabases as needed.
  • Install ArcGIS 10.0 SP4 or later to import the XML workspace document.
Article ID: 000011395
Software:
  • ArcMap
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
