HOW TO
Instructions provided describe how to implement the extract function in HTML Viewer. Using Extract Server in ArcIMS, it is possible to extract certain features of specified layers of an Image Service into a set of shapefiles, yielding one shapefile for each layer. Data can be extracted from shapefiles and ArcSDE vector layers served on an ArcIMS Image Service.
The out-of-box HTML Viewer does not include the necessary code to perform the extract function. This article explains how to customize HTML Viewer by adding the extract tool.
Upon clicking this extract tool, the data is extracted from the active layer within the map's current extent into a ZIP file, and the user is prompted to download the ZIP file.
Note: For more information on extract functionality of ArcIMS, see the "Using GET_EXTRACT and EXTRACT" section in ArcXML Programmer's Reference Guide.
Note: Steps 5 through 9 outline the individual code changes to enable the extract function for the aimsCustom.js file. A complete aimsCustom.js file, with all of the necessary code changes, is listed in step 10. This code can replace the existing contents of the aimsCustom.js file.
<LAYER type="featureclass" name="redlands" visible="true" id="0"> <DATASET name="redlands" type="line" workspace="shp_ws-0" /> <SIMPLERENDERER> <SIMPLELINESYMBOL width="1" captype="round" color="27,227,227" /> </SIMPLERENDERER> <EXTENSION type="Extract" > <EXTRACTPARAMS clip="true" /> </EXTENSION> </LAYER>
Note: To enable the Extract Server, an Extract extension must be included with at least one layer in the map configuration file.
var useExtract=false;And change it to:
var useExtract=true;
var extractXMLMode=1111; var imsExtractURL = imsURL + '&CustomService=Extract'
function useCustomFunction(theReply)Change the function to look like the code below:
function useCustomFunction(theReply) { if (XMLMode==1001) { // Insert code here. } else if (XMLMode==1111) { parseExtractResponse(theReply); } else { alert(msgList[55] + XMLMode + msgList[56]); } hideLayer("LoadData"); }
function extractIt() {Change the function to look like the code below:
// Extract layers to download. function extractIt() { hideLayer("measureBox"); //alert(msgList[51]); if (checkIfActiveLayerAvailable()) { sendExtractRequest(); } }
function sendExtractRequest(){ var extractAXL=""; //extractAXL += '<?xml version="1.0" encoding="UTF-8"?>\n'; extractAXL += '<ARCXML version="1.1">\n'; extractAXL += '<REQUEST>\n'; extractAXL += ' <GET_EXTRACT>\n'; extractAXL += ' <PROPERTIES>\n'; extractAXL += ' <ENVELOPE minx="' + forceComma(eLeft) + '" miny="' + forceComma(eBottom) + '" maxx="' + forceComma(eRight) + '" maxy="' + forceComma(eTop) + '" />\n'; extractAXL += ' <LAYERLIST>\n'; extractAXL += ' <LAYERDEF id="' + ActiveLayer + '" visible="true" />\n'; extractAXL += ' </LAYERLIST>\n'; extractAXL += ' </PROPERTIES>\n'; extractAXL += ' </GET_EXTRACT>\n'; extractAXL += '</REQUEST>\n'; extractAXL += '</ARCXML>\n'; sendToServer(imsExtractURL, extractAXL ,extractXMLMode); } function parseExtractResponse(theResponse){ var extractURL = getURL(theResponse); //alert(extractURL); if(extractURL!="") var Win1 = open(extractURL); }
// aimsCustom.js /* * JavaScript template file for ArcIMS HTML Viewer * dependent on aimsXML.js, ArcIMSparam.js, aimsCommon.js, aimsMap.js, * aimsLayers.js, aimsDHTML.js * aimsClick.js, aimsNavigation.js, */ // Global variables aimsCustomPresent=true; // Change these to send XML response to custom function. // Use numbers >= 1000 and match in useCustomFunction(). // Defaults are defined in aimsXML.js and use standard functions. // xml response mode for selection selectXMLMode = 6; // xml response mode for identify identifyXMLMode = 7; // xml response mode for query queryXMLMode = 8; // xml response mode for find findXMLMode = 14; // xml response mode hyperlink hyperlinkXMLMode = 15; var extractXMLMode=1111; var imsExtractURL = imsURL + '&CustomService=Extract' // Custom function for handling clicks // flow redirected here when // toolMode set to >=1000 function customMapTool(e) { if (toolMode == 1001) { // Insert code here. return false; } if (toolMode == 1002) { // Insert code here. } } // Send XML response to custom function // flow redirected here when // XMLMode >=1000 function useCustomFunction(theReply) { if (XMLMode==1001) { // Insert code here. } else if (XMLMode==1111) { parseExtractResponse(theReply); } else { alert(msgList[55] + XMLMode + msgList[56]); } hideLayer("LoadData"); } // Add custom stuff to Map XML request. . . between selection and geocode. function addCustomToMap1(){ var customString = ""; /* customString += '<LAYER type="ACETATE" name="theMode">\n'; customString += '<OBJECT units="PIXEL">\n<TEXT coord="5 ' + (iHeight-10) + '" label="This is a test">\n'; customString += '<TEXTMARKERSYMBOL fontstyle="BOLD" fontsize="12" font="ARIAL" fontcolor="' + modeMapColor + '" '; customString += 'threed="TRUE" glowing="' + modeMapGlow + '" />\n</TEXT>\n</OBJECT>'; customString += '\n</LAYER>\n'; */ return customString; } // Add custom stuff to Map XML request. . . between clickpoints and copyright. function addCustomToMap2(){ var customString = ""; return customString; } // Add custom stuff to Map XML request. . . under modeOnMap. function addCustomToMap3(){ var customString = ""; /* customString += '<LAYER type="ACETATE" name="theMode">\n'; customString += '<OBJECT units="PIXEL">\n<TEXT coord="5 ' + (iHeight-10) + '" label="This is a test">\n'; customString += '<TEXTMARKERSYMBOL fontstyle="BOLD" fontsize="12" font="ARIAL" fontcolor="' + modeMapColor + '" '; customString += 'threed="TRUE" glowing="' + modeMapGlow + '" />\n</TEXT>\n</OBJECT>'; customString += '\n</LAYER>\n'; alert(customString); */ return customString; } // Add custom stuff to Map XML request. . . on top of everything. function addCustomToMap4(){ var customString = ""; return customString; } // Extract layers to download. function extractIt() { hideLayer("measureBox"); //alert(msgList[51]); if (checkIfActiveLayerAvailable()) { sendExtractRequest(); } } function sendExtractRequest(){ var extractAXL=""; //extractAXL += '<?xml version="1.0" encoding="UTF-8"?>\n'; extractAXL += '<ARCXML version="1.1">\n'; extractAXL += '<REQUEST>\n'; extractAXL += ' <GET_EXTRACT>\n'; extractAXL += ' <PROPERTIES>\n'; extractAXL += ' <ENVELOPE minx="' + forceComma(eLeft) + '" miny="' + forceComma(eBottom) + '" maxx="' + forceComma(eRight) + '" maxy="' + forceComma(eTop) + '" />\n'; extractAXL += ' <LAYERLIST>\n'; extractAXL += ' <LAYERDEF id="' + ActiveLayer + '" visible="true" />\n'; extractAXL += ' </LAYERLIST>\n'; extractAXL += ' </PROPERTIES>\n'; extractAXL += ' </GET_EXTRACT>\n'; extractAXL += '</REQUEST>\n'; extractAXL += '</ARCXML>\n'; sendToServer(imsExtractURL, extractAXL ,extractXMLMode); } function parseExtractResponse(theResponse){ var extractURL = getURL(theResponse); //alert(extractURL); if(extractURL!="") var Win1 = open(extractURL); }
Get help from ArcGIS experts
Download the Esri Support App
