HOW TO
Identify equivalent widgets from Web AppBuilder to Experience Builder using a Python script
Last Published: July 25, 2025
Summary
ArcGIS Web AppBuilder in ArcGIS Online will retire in the first quarter of 2026 and ArcGIS Enterprise 11.5 is the final release to include ArcGIS Web AppBuilder. Users will need to migrate their applications from ArcGIS Web App Builder to ArcGIS Experience Builder.  This Python script helps identify widgets in Web AppBuilder apps that have equivalent widgets in Experience Builder for applications in ArcGIS Online or ArcGIS Enterprise. It is important for users to know which widgets and functionalities in the Web AppBuilder application are available in Experience Builder. Please note that some ArcGIS Web AppBuilder widgets will not be literally migrated to ArcGIS Experience Builder because their functionality can be found in other equivalent Experience Builder widgets.
Procedure
The script recognizes all the Web AppBuilder applications in an ArcGIS Online or ArcGIS Enterprise account. The script outputs a table of all the widgets in each Web AppBuilder application along with equivalent widgets found in ArcGIS Experience Builder. You can also filter the applications for a specific owner within your organization account.
To run the script:
  1. Open the ArcGIS Online item to download or access the Notebook Python script.
  2. If you access the script within an AGOL Notebook, you can authenticate with default GIS("home") OR use one of the other two authentication methods provided in the script. ArcGIS Enterprise uses can run the script with either Notebook Server or locally with a Python notebook client like Jupyter Notebooks.
  3. Optionally, filter for a specific owner by replacing user with the desired owner's ArcGIS Online username. If not, leave the "*" to output all Web AppBuilder applications within your ArcGIS Online organization.
  4. Optionally, replace appCount with the desired number of applications output.
  5. Run the first cell for authentication.
  6. Run the second cell for results.
Article ID: 000033006
Software:
  • ArcGIS Online
  • ArcGIS Experience Builder
Get support with AI
Start chatting now
Related Information
Discover more on this topic
Get help from ArcGIS experts
Contact technical support
Start chatting now
Go to download options
