PROBLEM
Hyperlinks are not enabled in an ArcIMS HTML website.
The hyperlink array is not correct in the ArcIMSparams.js file.
Code:
// parameters for setting up hyperlinks in data display
var hyperLinkLayers = new Array(); // layers to have hyperlink
var hyperLinkFields = new Array(); // field in those layers to be used for hyperlink
var hyperLinkPrefix = new Array(); // prefix (if any) to place before field value to make hyperlink url
var hyperLinkSuffix = new Array(); // suffix (if any) to place after field value to make hyperlink url
hyperlinkLayers[0] = "Parcels";
hyperlinkFields[0] = "QUICKREFID";
hyperlinkPrefix[0] = "http://www.zephyr.com/Appraisal/PublicAccess/PropertyDetail.aspx?PropertyID=&dbkeyAuth=Appraisal&TaxYear=2005&NodeID=11&PropertyOwnerID=";
hyperlinkSuffix[0] = "";
Code:
hyperlinkPrefix[0] = "http://www.zephyr.com/Appraisal/PublicAccess/PropertyDeatail.aspx?PropertyID=&dbkeyAuth=Appraisal&TaxYear=2005&NodeID=11&PropertyOwnerID=";
Get help from ArcGIS experts
Download the Esri Support App
